60' is where the ET is. Stacking gear will make it 60', if it doesn't spin the tire excessively. It's a balancing act. Again, do you want to get up on the tire and go fast, or stick it and do the same thing every time. If you use radials, that's a different situation.
If the results don't match the theory, change the theory.
