Originally Posted By NANKET
The upper door woodgrain on 70 GTX has clips similar to those, been a while since I looked at them. You can carefully compress the tabs and reuse the clips. That being the case when you see used panels for sale the clips are never with them probably get torn off on removal.
You are correct. I got the answer on for b-bodies only dot com
