I went to check the car out and it turns out it's a console automatic. Didn't check the numbers on the trans as it was in an enclosed trailer but the numbers I checked on engine, tag, VIN plate matched and he had the build sheet as well. Unfortunately there was a lot rust on the car, the floor pan, trunk, rear frame rails all in bad shape. The pass side torsion bar crossmember had a hole big enough to fit my hand through and someone replaced the rear quarter panels at some point but not a very good job.
