Originally Posted By rickb67
I SENT THEM TO DUANE PORTER LAST YEAR.
That is the right guy to send them to. If Dwayne did the heads then you should be ready to go. He'll probably have a record of what the combustion chamber size is too and he can provide you with a cam recommendation if you don't already have a cam.
Do you have a Stage VI intake? If so, 4150 or 4500? You'll need a 4500 intake and carb to make the bigger power.
