Originally Posted By rickb67
I WANT THE BEST. I HAVE STAGE 6 HEADS I WANT TO BE 12.5 TO 13 COMP. BORE SIZE WILL DEPEND ON THE KIT. I WILL RUN A ROLLER CAM.
What cc are the heads? You'll need to know that to pick the correct piston. There might not be an off the shelf stroker kit that gives you what you want. If it was me I'd use a Molnar crank with 7.100 rods and then look for a piston that gave me the compression ratio I wanted.
Are your Stage VI heads any good? I think they would be the weak link in your engine.
