With a variable switch you want to find the High speed hot wire, witch I think is the brown wire. Feed that from your pos. of your variable control.
That's the easy part. The tricky part is getting the Wipers to Stop in their Parked position. But maybe you don't care about that. You can always shut them Off in the parked position by turning the variable switch off at the desired time.
