Originally Posted By BlueRacer69
Originally Posted By Guitar Jones
It's really not much different than straight antifreeze, I wouldn't spend the extra money on it.
I agree. It cost to much. Fill it with Distilled water, a bottle of water pump lube, and 1 or 2 gallons of good anti-freeze, depending on where you live in the country.
:Iagree:
But if you live in an area that doesn’t get below 25 degrees and it’s garaged...
Don’t run antifreeze at all. Lousy at transferring/removing heat from motor.
