Keep these PINs per a 94 dakota service manual
PINS
1 map sensor
2 ECT sensor
3 Battery feed
4 sensor return
6 5v supply
7 8v supply
9 Ignition feed
10 not needed with 727
11 Ground
12 Ground
13 Inj Driver4
14 Inj Driver3
15 Inj Driver2
16 Inj Driver1
17 Inj Driver7
18 Inj Driver8
19 Ign Coil Driver
20 Gen Feild Driver
21 Air Temp Sensor
22 TP Sensor
24 Reference Pickup
25 Data link
27 AC compressor (if keeping AC)
29 Brake sense (if keeping cruise)
30 P/N switch
32 MIL
33 VSS (if keeping dakota cruise) we got rid of)
34 AC WOT relay (if keeping ac- we got rid of)
35 EGR Solenoid (we deleted EGR)
37 Trans OD light (we got rid of)
38 Inj Driver5
39 IAC
40 IAC
41 Heated O2 Sensor
43 Tach (we kept)
44 CMP sensor
45 Data llink
47 VSS pick up (we kept for now) KEEP 47-50, 53 keep if using dakota cruise
48 VSS set/coast (we got rid of)
49 VSS on/off (we got rid of)
50 VSS resume/accel
51 ASD relay and fuel pump relay driver
52 Evap purge (we got rid of)
53 VSS vent (we got rid of)
54 EMCC solenoid (we got rid of)
55 Trans OD solenoid (we got rid of) (keep if using 42rh or 46rh)
57 ASD bat supply
58 Inj Driver6
59 IAC
60 IAC
This is what I used to make mine work.
And pin#3 direct battery fused at 30 amps spliced to feed pins 30 of ASD and Pin 30 of fuel pump relay
Pin 9 IGN switched voltage spliced to feed 12v side of ASD and fuel pump relay.
Pin 11 and 12 grounds.
Pin 29 to brake switch
Pin 30 to park neutral switch
Pin 51 Switched ground wire to Pin 86 on ASD and fuel pump relay
Pin 57 pin on 87 on ASD relay
I also had a 1994 Dakota Service manual and a good understanding of
electronics. Hope this helps I think you may still find this in the tech archives also
