Firecore got every plug boots you need BUT the 135° ones when I ordered my second set, which are used on 8 and 1 plugs as far I recall?. ( I'm sure at least the 8th ). Since they didn't have the 135° degrees boots offered to install 90° but I told them didn't install any, because I could reinstall the ones I have on my running set
I sent them the CORRECT measures for 73 and lates setup, WHICH IS A DIFF LENGHT SET than pre 72s
With a Charger born in Chrysler assembly plant in Valencia, Venezuela
