440 .055 over.
Just shy of 4100 with me
Best of 10.88 @ 123.
4.30 Dana with spool on 30x9 Hoosier
8” PTC with a low gear set 727.
Here goes the build.
440 Indy EZ-1 With Roller Cam
75 440 Block .055 Over No fancy torque plate hone. Wish I had though.
Stock 440 Forged Crank, -.020/.020 on Rods and Mains, CB527P20, MS1277P20
SH876S Cam Bearings,
ARP 627-3000 Main Bolts
Indy EZ-1 Max Wedge Heads, 2.19/1.81, PAC 1386 @ 1.925" 280/640, 513 SR
Intake Lift Flow Exhaust Lift Flow
.100 71.8 .100 59.3
.200 128.0 .200 96.7
.300 190.6 .300 130.7
.400 246.5 .400 158.0
.500 300.0 .500 183.8
.600 337.9 .600 200.7
.700 349.3 .700 213.6
.800 343.4 .800 221.1
T&D 1.6 Rockers 8215
Pushrods Manton Series V, 3/8 .120" 9.710 EL
NGK R5671A-8 Plugs, Gap .035
Comp Mechanical Roller Cam,
Custom Grind
.721 lift Intake .711 lift Exhaust .451/.445
268 Intake
276 Exhaust
110 Center Grind @ 106
Jessel Roller Lifter S905820-50
Cloyes 9 Way Billet Timing Chain 9-3625TX9-5
Indy Single Plane Manifold
AED 1050 Dominator
91 jet, PIB .070, PHS .031 SIB .070 SHS .031
IB .059 SQ .035
MSD 7AL-3 7230
MSD Distributor 85463 (Locked Out)
JE SRP Forged Race Pistons .055 11.01-1 CR 213458
Total Seal File Fit Rings, CR9190-130, 1/16, 1/16, 3/16, .020,.020 Gap
Eagle H Beam Rod, .990 Pin, 6760B3D
1009 Fel-Pro Head Gasket, .040 Thick
Manley Head Bolts 42198
ATI Balancer 917122E SFI 18.1
Dougs Headers D452
Moroso Vac Pump 22641
For what is in it and how heavy the car is I can’t complain.
