I have used the JEGS brand fittings with no problems. The Russel fittings are OK, but the ProClasic hose is pretty stiff to get into the fittings. Been told to warm the hose to make it easier to install. Been using the expensive Aeroquip StartLight hose. Pretty easy to assemble.
