Originally Posted By BDW
Originally Posted By Bob J
PA is like Colorado not flat land but mountains. Tell me brake fad doesn't matter coming down a mountain pass of 10,000 ft.and drop 3 or 4,000 ft. that is twisty. Granted some folks live in the flat lands so it might be a issue for them. We have cut offs on some pass's that go uphill and is sand for run a ways when the brakes fail.
No argument on brake fade, but you're much better off improving the front brakes.
Only when those are no longer the limiting factor, improve the rear.
Especially in your scenario, coming down a mountain the front brakes will see even more heat because of the exaggerated weight transfer.
I already have a wilwood kit on the front. Since I'm swapping to a dana 60, I'm buying new brakes for the new rear while I'm at it. Since im starting from nothing with the rear, that's why I'm considering the discs. Is there any problem with the green bearings in the rear. I've heard that the original version had problems but the newer vesion was ok. I don't want to go through the trouble of buying a new rear and installing it just to have bearing issues later on.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
