Got one to jump out by putting drum on until it leaves 3 or 4 lug nut threads sticking out through drum. Then put 2 different 1/2 inch pry bars between backing plate and back of drum, then spun a couple lug nuts on opposing studs, couple turns at a time, kind of using a puller effect to pull axle out. Worked for me.
