It appears this carb started life as a 3 circuit, and switched to a 2 circuit, now my question,, was the idle circuit moved over and then the unused spot plugged with a undrilled bleed or am I seeing this correctly because once I get realeased from my cardiologist and able to dial my reworked 8082 dommy in, I am going to switch my 8896 3 cir to a 2 cir.
The highs remain next to the bowl vents, the inners are now idles and the outers get plugged..........
72 Dart 470 n/a BB stroker street car `THUMPER`...Check me out on FB Dominic Thumper for videos and lots of carb pics......760-900-3895.....
