When the OP gets around to checking off just the basics, before attempting a tune on the carbs, a member here sells special base plate screws and the required tool to make adjustments, esp on the rear carb easier while running, simple swap... contact Bud Weaver at Sixpack Solutions (Moparts member 69sixpackbee)
