Anybody used the Mopar performance aluminum dual plane intake pn P4529117 It has an rpm range of idle to 5800?
If you can find one , it's no longer made , that intake is an alum copy of the 70/72 factory 4bbl and should clear air grabber using the stock 383 base.
