Yeah I knew the radial would not grow at speed. But I do need a min of 28" if I'm going to do any 1/4 mile passes. Most will be 1/8 but I would like to see if I've been able to tune it anenough to get a high 10 sec time slip out of this tank.
Called Mickey Thompson and they said it should measure 88" in circumference when mounted on my 8" rim. Was told the radials do not vary like the bias ply. If not it is defective and I could return them. I'm going to follow up w/Summit and see if everyone is on the same page. Me
