Thanks for the replies. The rims I currently run were drilled for screws as I always ran slicks. Will these holes be a problem when I switch over to radials? Would rather not have to buy a ne set of rims if I don't need to. They are just steels but its still another couple 100 I can use elsewhere.
Ok
