the adjustable valve does not come with the pump cover - are you using the Milodon Billet pump or a factory pump - 99% of the time the pump cover is over tightened and it makes no difference with the old or new style cover - both can distort enough to create the issue
I agree...
I personally prefer the pumps that Wescott made but they are kinda hard to come by. I did have a relief valve issue with a KB pump twice. I have also had good luck with Titan but after the fire I am not sure they are available now either.
