Troy, I do not have a picture of the rear brakes but I believe you are correct about the strut for the parking brake. I thought HD brakes did NOT have self adjusters. Anyhow, here is a pic of the front brakes on nmy 69RR.
John, I'm starting to think that myself about the adjuster,, at least for the front. So, on your R.R, you didn't have self-adjusters on the rear either? I found two of the short thick springs just like the ones on the bottom that hold the lower shoes together and add resistance to the adjuster. Didn't want to, but I guess I can tear into my '69 C500 and see the setup, should be the same....
That's correct. No self adjusters on front or rear. I do not have a scanner, but on page 5-6 of the 69 Dodge manual are pictures of the front and rear HD and police brakes. No self adjusters, strut only on rear for parking brake.
You referring to the 69 Service Manual? I was looking at my '68 Service Manua and apparently, they only show the 10" with the adjusters within the brakes section. I'll take a look at my '69 Service Manual............
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
