I’m getting ready to drop my 360 magnum motor that I had done up with a cam grind from bullit cams, new heads and added a carb style intake into my 70 satellite. Car is originally a slant six car auto. What will I need to drop this in? I’ll keep it a auto trans right now just to make it simple.
I kept the serpatine belt set up on the front of the motor.
I’m missing all the brackets for alt and power steering but I should be able to find easy.
Can I buy motor mounts that will work on the 6 k frame?
What’s style trans should I use? Any 727?
What converter?
How will I get the power steering to work?
What do I go with for alternator?
