all the starters are the same. There is a set of $3 contacts inside that flatten out over time. I have used the same starter for over 15 years on 2 different engines. First one was 12-5-1 and the last one was 14.75-1. It will go right back on my new engine. I buy the exact starter you have listed V-8 1500 for other peoples projects with no problems. Birdtracker
