I ended up using a relay....12volts from the battery...triggered from the starter relay yellow wire....tied into the blue 12volt run wire at the ballast. Started right up ! I still think I'll source a diode though. I like that better to try and keep the engine compartment as uncluttered as possible. We already have all the Sniper harnesses to add to the clutter!! LOL
