Originally Posted By csk
Need to hook it up with a relay hooked to battery power, triggered by the ign switch.
I'd like to see the schematic for that. Seems to me you have to trigger the relay with either J1 or J2. If you tie them together then you defeat the purpose. So I don't see how a relay solves anything.
This question has come up before and the only solution I've seen that appears to work uses a diode to tie the two circuits together without allowing the start voltage to bleed into the run circuit.
