With roller bearing cam bearings you are going to have the lifter bores drilled and tapped for restrictors for push rod oiling. I built a 9.20 deck, 4" stroke 6" rod. Comes out to 440 topped off with shady dell w9's. Made around 740 hp pump gas.Check out shady dells webs site, explains plenty.
