I really hope someone on here can help me with this. I am running a 04 Hemi from a Durango, stock p/s pump. On the pressure fitting is there an adaptor fitting that will screw into the stock port? It is very deep so standard fittings will not reach. This car has hydroboost so I really need to find something that goes to jic/an. Is the stock fitting removeable? Spoke to a couple places that deal with gm pumps that make a fitting for those but nobody can tell me the thread size for the Hemi pump. Can't be the only one to run into this. Help
