Do you have a good cherry picker?
If so I would remove the intake and use a good thick 3/8 inch diameter chain and bolt it onto the most rear passenger side intake bolt(throttle return bracket bolt on stock heads) and the left front throttle return bolt hole and keep the chain as short as possible and go for it up scope twocents
If you don't experiment you don't learn shruggy grin
Some lessons aren't as pleasurable as others whistling
