Originally Posted By SportF
IF you are talking front pump seal, they are the same 62 up.
I think the 65 has a rear pump (can you push start a 65?) IF so, you should install a 62-65 filter. This early filter has an extra hole for oil pickup for rear pump.
Best of luck.
Yes, there are instructions for push starting a 65 in the owner's manual.
