Hi Josh!
Thanks for getting back to me. What wheel size and tires are you running with that backspacing.
I ask because my 1969 Superbee has a backspace and a front space of 6-3/4. So I was thinking of going with 6-1/4 backspace for clearance. I would like to run a 15x10 wheel, but with that backspacing, it will cost me a fortune for 2 wheels. So I am at a real loss what to do using M/T 325/50x15, with a section width of 13 inches.
Josh, click on my username, and see my email address and email if you would please..
Thanks so much for all the help,
Tom!
I have 4.75" back space. they are a little close for me, and will rub a little on the inside wheelwell if I corner it to fast. 90% of the time they dont rub and I am not concerned about it. I think 4.5" would be perfect, I may try a 1/4" spacer and see if it helps. The passenger wheelwell is bigger than the drivers side wheelwell. I guess that is just 1968 quality control.
