The float may be full of fuel? so no amount of adjustment is going to correct it, the black plastic floats are really susceptible to becoming fuel logged, even brass float can develop pinhole leaks and take on fuel, fooling the needle seat into a "low" fuel need, when in actuality the float level is to high...is fuel being pulled over into the secondaries at idle? visible while looking down the secondary throat at idle?
