Let me see if I understand, are you saying that when the shaft, and associated parts are in the coupler, and secured with the roll pin, and the hole in the shaft is 13/ 16ths from the coupler, that the column won't bolt up under the dash? Is that what you are saying? I have a reason for asking this.
