sorry you are wrong about that part because they couldn't bring the car down over the engine on the assembly line (to wide) so they farmed it out to the guys that built the 68 hemi cars. i have alot of paper on this
I've read many articles regarding who did put the motor/trans into the M-code A bodies and the general consensus was that ma Mopar did it and not Hurst-Campbell like first reported.I would like to see copies of the paperwork you have on this.When I restored my 69 GTS M-code I installed the motor w/exhaust manifolds,trans,and k-frame from the bottom,it does fit.Now I don't have the build sheet for my car,but it is matching #'s and it has an 093 trans in it,with a sbd of 3-29. John.
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
