Originally Posted By 70satelliteguy
I am using a "Flex-Hone". Has a whole bunch of little black balls on it.
Instructions says to not use any solvent!
Used a Mixture of Transmission fluid and WD-40(or as my wife calls it, DW-30!). Worked great. Was just a deglazing hone for new rings so a quick 20 seconds on each cylinder did the trick.
Thanks for the reply's.
Mike
When a shop hones the bore it is only about 6 passes on the bore so I don't know if any extra will harm things.
GOTBOOST!New improved with Victor heads.
http://www.enginelabs.com/mopar-big-bloc...t-of-necessity/
