On my 69 Bee I have a Tanks Inc. efi tank with pump in the tank. I am running Russell pro classic II hose 3/8. I'm trying to find the cleanest and safest way to route the lines was thinking about running them across the back of the shock cross member and then down to the tank. Is it ok to have the lines go uphill like that right out of the tank? First efi system trying not to screw up. Anyway I run them they have to go uphill in the wheel well pretty much no matter what. Is a pump in the tank ok to push fuel like that? Return style system if that matters. Anyone running something similar? links? Thanks guys
