I have '73 barracuda with 400/727. I am going for the prostreet look so I will not be slashing corners road racing. I just need a decent ride.
I want it to sit fairly low but I am not sure how to pick a coil over.
Can someone help me with a budget-minded choice?
thanks !
Stick with your torsion bar set up, and stock arms, add a set of drop spindles, you can get upwards of 2" offset/drop, PST, Magnum Force, Reids, etc, etc, etc offer a host of drop spindles for the E body, slam it as low as you can, modify the rebound bumpers for added suspension travel, add a skid plate on your K for your oil pan
