Chief aircraft and Aircraft Spruce both sell a liquid aluminum corrosion remover, maybe the name is Aladyne confused Maybe not it's been way to long since I've bought and use it on my old airplane shruggy It works very well doing that corrosion scale removing up
Call them to get some twocents
I have also used Eagle Cast Aluminum wheel cleaner on intakes to clean them up so they look good work shruggy
