In tank pumps are reliable. I doubt you can put an electric pump on the end of the factory sending unit. Why would you want to? I have an Aeromotive Stealth 340 in the GTX and a Walbro 255 in the Charger. Both are set up with return and both use carb. Both work good and both are reliable.
