I'm running an 8 3/4 rear end, cleaned inside thoroughly, Torsen diff w 3.91's, Moser axles & Dr Diff econo disc brake kit.
I'm getting a noisy passenger side bearing again after only a few thousand miles. I changed both bearings the last time I had this noise, and it was quiet for 3-4 thousand miles. Gear oil is filled to proper level.
I'll check the axle runout at the flange this week. Would a bent housing cause this?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
