Originally Posted By DoubleD
are you using the mopar lifters ??? never had luck with those - but spring pressure seems to be a little low at the seat - do you know what the open pressure was?
Have Crower "cam saver" lifters in it now. 1 turn of pre-load .020 I think?
Did use mopar lifters on it the 1st time.
Don` t remember open pressures
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
