Originally Posted By Centerline
Take a hammer and tap the starter once or twice. If it starts then the solenoid is the problem. A sticking starter solenoid is a very common problem when all of a sudden it won't crank.
FWIW, Last year I had the same problem. A tap on the starter got it working again, so replaced the starter. Long story short, the original negative battery cable was the actual culprit. rant hammer
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
