The qft blocks have the ifr in the upper position.
I wouldn't worry about moving them until you determine your combo can't seem to be made to run right with them in the upper position.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123
Dealer for Comp Cams/Indy Heads
