Originally Posted By relax383
Hey guys,I recently picked up a pair of W2 heads P5249769 65cc closed chamber. Flat pedestals. I know they oil through the push rods.
What rockers do you guys recommend?
I've never heard of any of the stock W2 race heads(with pedestals) using push rod oiling confused
As far as rocker arms, buy the best you can afford up
Don't go cheap tsk twocents
On the block as long as your not shooting for over 700 HP either block should work fine twocents That being said I know nothing about the magnum blocks, 318 or 360 shruggy
