Its a very tough epoxy paint. We tried using in the blind locations (inside quarters). Didn't hold up in that (mis)use. No paint will because the surface can't be prepped properly. If there is rust, use their rusty metal primer. Rustoleum rusty metal primer should be compatible, but that will be your risk if you want to try it instead.
