Originally Posted By coletrickle
Tape any body gaps etc. And the deepest stage you can do on your full pass.
Shallow staged = low ET
Your at the beach, you walk just into the water the water is shallow, keep walking the water gets deeper?Just swap Car for walking, beach for drag strip and water for the staging beams.is it backwards on land pretty sure its not.
Interesting analogy...... but the staging as shallow as possible will yield the fastest ET; and it’s generally a substantial difference.
LemonWedge - Street heavy / Strip ready - 11.07 @ 120
