I've had several ill handling cars at the track, do NOT OVER CORRECT If you start to feel uncomfortable lift your right foot a little or all the way off, DO NOT jerk the steering wheel around, make all steering inputs gently, a tiny bit, not a BUNCH 4 speed cars can get your schynter(SP?) really tight in a hurry at WOT Once it starts to make you feel bad do something to correct it Don't take time to think about what to do at WOT and then do something, don't freeze up
