Do you have a stock starter relay? If so, make the shifter supply ground to the brown wire on there. It is marked with a "G" and is sometimes hard to see because the brown wire's terminal has rubber around it. No power required. Attach the shifter's neutral safety switch to ground and run the other side to that brown wire's terminal. up
