having had the problem of plug wires getting hot & sagging down only to burn against the headers tubes, i went for the under the header plan. now when things get hot they tend to drop away from the headers which is a good thing if your racing & no longer changing to 7 cylinders at mid track. with this set up theres no chance of getting it wrong & crossing over plug wires as they only fit 1 way, the correct way.
