I'd pull the tank and have it boiled and sealed (or replaced), and I's also get a new pick up, fuel pump, filter, and rebuild or at least drain the carb and clean it. If you don't you might be chasing bad fuel gremlins forever, I hear it A LOT from my customers who've tried to cut corners.
