The T56 Magnum isn't that bad to pull out and service. I have done it myself when I had to flip the ring gear on my flywheel around. The worst part is putting everything back & aligning the trans so that the splines line up but its easy with the clutch tool and when you use the drive shaft to spin the input shaft. Also having the car on jacks as high as possible and a trans jack helps!
