Originally Posted By HOTMOPR
Better have your rear splines dead nuts if you have a spool in the rear..
a way around that would be to drill the axle bolt holes oversize, then use flange nuts with large, grade 8 washers to attach the stands to the axles. this would not affect strength of the stands, nor the attaching point strength.
beer
